Torque article
Very interesting. The predominate thinking has been that a long stroke engine is needed for high torque by means of the leverage provided by a rod pin that is further from the crank centerline. It turns out that piston surface area and valve/port size is just as important as the leverage provided by a long stroke engine design.
- 3 likes
