Race transmission
    Race transmission
    MRE race transmission, has arrived and ready for install, spiralloc circlips, micro polish, all new parts, its not automatic cut, aggressive street/strip, after 1st, shifts should be flawless with the blip of throttle when hooning or drag racing. Go Faster
    The circlips used are massive and look like an onion peeled. Im very excited to get in bike and to have sparky59 Norm and crazystagehand Gary over for a weekend to dial in the cams. Hopefully soon to Konrad for a full tune, timing and fuel.
      Wish i knew what im looking at, is all greek to me
        Spiky round things on fancy sticks!
      Its motorcycle content.
        yeah but from the inside, i can only identifie the outside
          What does not automatic cut mean?
            I just meant this is not automatic as im having a automatic transmission cut by MRE for the drag bike. Maybe
              The term automatic transmission as far as a rocket is concerned the transmission would be modified, the dogs would be cut with the normal angle like Robinson does on the engagement side of the dogs and then also a ramp on the backside of the dogs would be cut so as you lift up the shifter linkage to select the next gear it would automatically take itself out of say second gear and because you picked up on the shifter linkage it would shift into third no clutch needed no delay in power. However there is a drawback....you can only upshift the trans while under power...downshifts are done while stopped... not a street trans...race only.
                But im pretty sure you knew this info was there. Oh i get it, looking out for those that may not know. Haha fuck no bustin my balls 😂😂😂😂
                  sounds great
                    sounds great
                      No, I had no idea what you were talking about
                        Bustin your chops bro😀 big bro
                          Barbie!
                          You are for real going to split cases and install a tranny that can not be down-shifted unless the bike is at a stop???
                            That's a good thing, then he'll have to buy mine to have something rideable
                          No sir😂
                          Barbie!
                            Is that what it means?????????
